So far the only IC in general that's outright been bad is the ECS one. It's 1 of 2 FMICs tested so far (other being a Baun V1).
I collect logs of cars on
TRACK - this does not reflect street performance. Realistically speaking they'll likely all be pretty similar for a single pull or two I imagine. Refer to Jeff's testing for stuff more along those lines. IMO a 5-10F difference from one to another isn't even worth bothering if you're just looking at street pulls. If long term you want more POWER then unless it's a higher flowing core, it might become limiting at some point.
IMO the main advantage to a FMIC is that you can run the A/C and not have the hot condenser air add 8ish-15F to your IATs on average - how much exactly will depend on how hot and humid it is outside. It's not a straightforward number.
Back to the track cooling stuff:
Full cooling reports here, with info on how these are collected:
https://www.datadrivenmqb.com/drivetrain/coolingdata
The fact is under sustained hard use/constant lapping
most all of the intercoolers perform about the same (all min and average values fall within a ~10F window of each other).
@GTI Jake 's IC is right there with all the others, and I would expect any of the cheaper FMICs with smaller cores to perform more along the lines of the ECS one - though that's just speculation until some more actually gets tested. I'd like to see a CTS one since they're relatively popular.
Stock location have the advantage of a TON of surface area, FMIC have a minor location advantage, but IMO is mostly a moot point if A/C is turned off.
IAT delta min is probably the most relevant.
IAT delta max is going to be moreso dependent on track (time in turns off-throttle where the IAT creeps up due to lack of airflow through the manifold - even though the IC itself is probably cooling off)
IAT delta avg is worth considering since most samples are all in the ~50%-60% TPS average range when on track.
It's not "cheap", but the Mishimoto IC is cheaper than the DO88 and is great at dropping IATs even when heat soaked - meaning even better on the street. I DO have concerns that it might be more restrictive in airflow getting to the radiator under track conditions (look at
@MonkeyMD 's logs in the link above)... but this would never be a concern or a problem on the street.
Also if you haven't gone through your cart yet - the shipping on the DO88 IC is STEEP. That's what I run, and IIRC added another $100+ to the cost because it's coming out of Sweden, unless EQT now stocks them locally - this was not the case when I ordered from them last year.
