I suggest not buying from Autrey and BMP then.
What's wrong with Autrey/BMP?
I am looking at getting the i.e intercooler and will be running an is38 i was looking over some stuff oblivious had posted on cfms and sizing your ic and I would have to agree that it's seems the Wagner seems a bit large for is20 but it should be good for the is38 now my question is do you all think the i.e might be small for the is38. I like i.e and all there products but I'm looking for a proper set up to reduce some stress off the is38. I do how ever like the Wagner also and have heard nothing but good things from it. If the Wagner is better suited for the is38 I'll get that one plus I live in Arizona when the summer is in the 120's.I have to agree if we are talking about an IS20 car. The Wagner is too big IMO.
Sent from my XT1254 using Tapatalk
Thanks I grazed over that thread and missed that part but found it and looked at the log. Good cause I wanted the i.e lolLook at the VTT turbo thread and those logs. Looks like it handles it just fine.
OP was a Golf R
OP would be Oblivious and he doesn't have a Golf R. If you are saying Mabotech guy thinks it is worse than Golf R IC on a Golf R then I can't comment, have not seen enough data.
How heavy is the cts core on that fmic kit? A rough estimate will work too.
The conditions had to be a little different for these runs, or the stock IC wouldn't start out 16c higher. Regardless, it is the trough to peak that matters and the stock IC went up 11c while the CTS went up only 5c. So it's twice as good as stock at cooling.
