You don't need to get so worked up over this. Not trying to start an argument here, just throwing out my $.02. We are basically talking about semantics at this point.
An aftermarket IC isn't going to magically give you more power. All it does is
help with making more power. Just like how an upgraded intake makes the engine more efficient which results in more power being produced by the engine.
The car's ECU doesn't know that the IC has been changed. However, it can see the benefits from the upgraded IC.
An IC's job is to cool the charge air, which results in the charge air being denser. Dense air contains more oxygen than non-dense air. Therefore, dense air is able to react with more fuel than non-dense air can.
This is why forced induction engines make more power when ambient temps are colder. There is more oxygen available in the cold air, which means more combustion is possible.
Taken from the following site:
https://www.getunitronic.com/news/unitronic-intercooler-upgrade-kit-for-1-8-and-2-0-tsi-gen3-mqb
Unitronic's bar and plate intercooler core is constructed of T5052 Aluminum featuring a unique staggered and louvered fin configuration to maximize efficiency, significantly reducing charge air temperatures allowing for cooler, more dense air to be ingested by the engine; ultimately resulting in an increase in engine performance. When intake air temperatures reach a specific threshold, the engine control unit begins to compensate to account for the air temperature, resulting in a decrease in performance. Unitronic's core has 64% more volume than stock measuring 23.5” x 2” x 16.5”, allowing for a greater volume of air to exchange heat, which, combined with a proper fin configuration, allows for maximum efficiency and reduction in heat-soak thresholds without producing a significant pressure drop.
Notice where it says "When intake air temperatures reach a specific threshold, the engine control unit begins to compensate to account for the air temperature, resulting in a decrease in performance."
Also, since cold charge air is more dense, the turbo will have to work less to make the same amount of boost. This helps to increase the engine's efficiency.
The point that I am trying to make with all of this is that the IC isn't what makes more power. The engine is making more power because of the benefits of the upgraded IC. The ECU sees that the charge air is colder and denser, and is able to safely inject more fuel and adjust timing because of that. The intercooler is helping the engine to be more efficient, which in turn, allows the engine to make more power, and be consistent about it.
