How to retro-fit the Mk8 rear suspension aero covers or stone guards to a Mk7 Golf.
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Do you think the plastic riv-nuts will keep the covers on at high speed?
People have done track days with them fitted like this all ok....read my reply a few comments up on why VW fitted the metal fixings....
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
The mk8 covers do not fit on MK6/MK5 rear LCAs. The design is different
Strange......as I was on the understanding that the rubber stone chip guards originally for MK5 which fit in the same place & use the same fixing points, fit all from MK5 to MK8 rear multi-link lower arms... :unsure:
Unless they modified them for MQB platform (MK7) onwards..?‍♂️
Group N
England
Mk7 Golf R
Today I fitted the Mk8 aero cover on a MK7 R.
A quick and easy job.
I just used 4 plastic riv-nut thingys on each and as others have said, they`re a nice and snug fit.
I don`t think they`ll be going anywhere.
Thanks to golfdave and all the other contributors to this thread.
bluedoggiant
MD/GA
Do someone people put the mk8 aero guard on the front of the vehicle? I am seeing people install it both ways. I can’t get it to fit with the mk5 silicone.
EDIT: I’m so dumb. I am just now realizing that you only choose one or the other. I bought both the mk5 and mk8 guards thinking they work together
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Oh bugger...!!!!.... :ROFLMAO:
Its the two options...either the MK5 onwards "stone guards" (rubber)....
OR the MK8 "Aero guards" (plastic)...;)
NOT BOTH at the SAME TIME......?...If you want to do it thats fine.......knock yourself out & report back....?‍♂️
EDITED original posts to make it much clearer that its one set.....NOT both sets!!!
bluedoggiant
MD/GA
So funny. I attached the silicone to the front side of the trailing arm, thinking the mk8 aero guard went on the back side. I was going insane it couldn’t fit. Pulled it off and installed the mk8 aero guard instead.
Bummer, the mk5 part cost 4x as much as the mk8 part! Silly me
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Others have done the same, ordered both sets...
Originally when I wrote this is the MK8 didn't exist..only the MK5 rubber set which I did the guide for... I then re-wrote & added the MK8 set into the same guide...I tried to make clear its two options, obviously not clear enough!!
EEeegolf
Finland
E-Golf
Short report on these aero covers.
I just installed them both front and rear on my e-Golf. Front didn't fit well as reported. But they fit good enough anyway and wasn't hard.
I did a baseline noise test just before installing and a test with them about 30 minutes later. Some place. Same conditions.
The measurement had the same result as subjective listening. Absolutely no effect.
I also did a aerodynamic drag test before but I have to wait for less traffic (night) before testing with the covers.
My Cd value vas a bit high. I have to study whether the electic drivetrain has more drag than coasting in neutral with normal gearbox. However, the difference will be visible anyway.
McBrian
So Cal
'16 Golf 4D 5MT
I threw a set on last week when I did my rear apron, made it so easy I didn't even have to lift it or take a wheel off. Used the plastic rivets and so far so good, we'll see how they hold up.
StokTdi
Ohio
2015 Golf Tdi
Yes there are MK7 parts to cover the MK7 torsion beam near the spring seats..also MK8 Golf/Polo part to cover the main cross piece section of the MK7 beam..
from the main aero trays how to guide I did:-
Hello @golfdave,
I know this is years later, but any chance you have the part number for the main cross piece section for the torsion beam? I have been unlucky trying to track it down so far and was going to order it along with the other 4 stone guards. Thanks!
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Hello @golfdave,
I think its MK8 Golf parts..or stuff from the Skoda Octavia as that had the torsion beam with the "eco parts"....somebody had done it on a Seat brand car...info somewhere in a post in my big thread on the skid trays...
https://www.golfmk7.com/forums/inde...nder-trays-stone-guards-to-a-mk7-golf.320687/
