So can I fit either engine tray 5Q0825236Q or 5Q0825902C just the latter is a skid tray. I notice 1st has a wavy edge & skid tray has a straight edge towards the rear.
Then use 5Q0825229C exhaust cover without the need for the Tiguan mod?
Rob.
The Tiguan cover is the only cover that fits the steel subframe to cover the steel subframe...the aero tray (noise insulation) or the skid tray items which are specifically made for the Mk7 Golf join onto the subframe but do not fully cover the subframe, this is obvious if you go look at the pictures in the start of this thread & the Tiguan cover thread linked to above...or look at the picture linked to above of the items laid out in their correct places...
The MK8 Golf thin plastic aero tray from the "eco" version which has the aluminium subframe is a huge undertray which covers the whole area of both the MK7 aero tray or skid tray & the Tiguan tray....BUT the rear fittings required might not work on the steel subframe.
If you don't want to drill your steel subframe don't fit the Tiguan cover...the front ray for the exhaust tunnel & either the aero tray (noise insulation) or skid tray are easy fits to all 2wd MK7 Golfs....also fit the rear exhaust tunnel trays, & the best bank for buck is the MK8 Golf aero covers which fit the rear lower arms if you have the multilink rear suspension...
