Are the front skid/aero plate and the tiguan aero plate exclusive of eachother or can you install both of them together? I understand that there is something going on with the "wavy" ends of each panel.
What subframe do you have, aluminium or steel??...
Also are you prepared to drill holes in the steel subframe as that is what is required for the Tiguan subframe cover...& do you have a large rivet nut installation tool?...
Its quite clear what will & will not fit as I state in each section what cars the items are for...but I'll reiterate..
You can fit the thin plastic aero cover or more precisely what VW call the diesel noise insulation. This is a straight bolt on undertray for the engine bay, no brackets required & has a wavy edge where it meets the subframe... OR you can fit the aramid fibre reinforced skid tray which requires two brackets at the front and has a straight edge where it meets the subframe.
IF you have the aluminium subframe you can fit the "Eco" very big thin plastic aero tray from the "Eco" MK8 Golf which covers the whole front subframe as well the same area as the above trays. No brackets required.
If you have the steel subframe you can fit the Tiguan subframe tray which fits perfectly against the VW noise insulation aero tray. However IF you have the aramid reinforced skid tray which has a straight edge you will have to cut a wavy edge in the skid tray to join upto the Tiguan subframe tray.
Tiguan subframe cover & either the noise insulation thin plastic aero tray or the reinforced skid tray together both cover the exact same area as the "Eco" very large MK8 thin plastic aero tray..
The front section of the exhaust tunnel, you fit the short tray, the long tray is not suitable for your AWD systems due to the prop shaft cardan joint bracket...
You cannot fit ANY of the rear exhaust tunnel or rear axle cover trays as your AWD systems are NOT suitable for this.
You can fit either the rear stone covers or the MK8 Golf aero covers to the lower rear suspension arms...
