[HOW TO PATCH Component Protection] MIB2 Technisat/Preh Headunit Patch(gps headunits only with 2 sd card slots)
Giannis20vt
Greece
GOLF MK7.5 TDI
I have ODB11 so i will proceed with the toolbox option, it is something i have done it already with the original software version 472T
So the link i wrote is the right one for my hardware ?
Giannis20vt
Greece
GOLF MK7.5 TDI
I have done this already. Of course watching this video. I think that my infotainment doesn't support voice commands.
Those are the supported FEC codes
ash9949
Poland
golf 7
try updating it and patching it
and later check the all fecs are activated and it should work, if not try manually activating the fec and swap
ash9949
Poland
golf 7
there is nothing like your mib cannot support voice unless if you dont have actual physical hardware like microphone in your domelight setup
just try watching the video and activating the voice fec
example
00070300 - VoiceControl (Online SDS with Nav)
00070200 - VoiceControl (SDS with Nav)
00070100 - VoiceControl (SDS)
these fec should be activated for voice to work
check these fec are in unsuported list
Giannis20vt
Greece
GOLF MK7.5 TDI
I have done the upgrade. Everything was correct. Now I have the 480 version.
Still can't turn on voice commands.
These pictures are from my infotainment and show supported trade-in codes.
No 00070100 or 00070200...
No idea ?
dawcioral
PL
MK7.5
It's possible but 480 don't have any noticable changes and if your unit is 03xx then don't risk with updates
I made a mistake. I checked the update history and the first version shows 0449. Can I update to 0480? As I wrote, I have a bug with the long start of the FM radio.
ash9949
Poland
golf 7
No idea ?
View attachment 283034View attachment 283035View attachment 283036
questions for you.
1. can answer and speak from bluetooth from your radio.? do you actually have microphone in your car installed in dome light .?
2. did you check unsupported fec code list in your mib 2 .?
3. did this mib 2 unit came with factory or did you retrofit it.?
4.which patch did you use .?
5.did you generate and inject all fec codes according your vin and other number according that video i had shared in above post .?
ash9949
Poland
golf 7
No idea ?
press and hold menu button
after that you will fec and swap function option
and take pictures of installed codes from top to bottom
and also take picture or supported codes from top to bottom
Giannis20vt
Greece
GOLF MK7.5 TDI
questions for you.
answers
1. Yes the Bluetooth is working fine.
2. What do you mean ?
3. Factory equipment
4. MIBSTD2_Toolbox-v1.3.1
5. I have done this with the previous version (472T), without any luck. The FECs injected but were unsupported.
