So just did a swap from the is20 to is38. It is now pissing coolant! Any ideas before I rip it apart again tomorrow?? Coolant is hitting the support bracket as well as next to the 02 sensor. Cannot see where it is coming from.
I just installed the is38. I put new rubber seals on all the lines. And tightened them down. Just wondering if anyone has had that happened to the coolant lines before. Going take everything apart again to check. Seems either the top or bottom coolant line to the turbo. The ones on the block are good. Oil lines are good.
When I reassembled after my is38 upgrade, that hole was weeping coolant. I didn't remember pulling a bolt out of there either! But is was weepong, so I plugged it...
