imthanick_a
- Ohio
I changed plugs to 1 step colder, Denso Plugs as recommended by APR. So drive the car a little and codes should go away?
What BavoMike said. If it is running rough, something is not right with the plug install. As stated when you drive the car the lights on cluster should go away, but it sounds like you have something else going wrong. I did not fully snap in a couple of connectors when installing plugs, so that could be going on.
Do this. Check your plug install, then if everything looks good, drive it a little. Don't go hard on it until you know its doing better. The ECU has to "learn" about its new fueling and air/fuel ratios
