SI0M6GBJ1
- MiddleEast
I enabled the stop lamps to go on altogether with the inner lights (the ones in the tailgate) and it works:
Final effect: https://youtu.be/FlVpzbtxplU (btw. blinking effect is just a regular PWM working on 27% interfering with the FPS ratio of my camera, not visible when looking at it)
The only problem that I have is that I cannot adjust the brightness of these inner rear lights to work 100% when braking or less when running on normal lights. On another thread I found information that it could be done using "(10)-Leuchte27NSL RC6-Dimmwert CD 27" set value to '100'
but if you do it this way, then even when you turn on normal lights, you got it 100% bright, so as hard as when stop lights go off. Not cool, so I left the default brightness settings here.
BTW. one cool mod is to use the 3 LEDs from rear lamp as rear DRLs (in EU/MEA) we do not have rear DRLs enabled when driving. Having only 3 LEDs turned on is awesome!
Those guys are responsible for those edge LEDs:
(10)-Leuchte2SL VLB10-Dimmwert CD 2' from 26 to 100
(10)-Leuchte3SL VRB21-Dimmwert CD 3' from 26 to 100
I would make some more pics, but while playing with it the battery died and my wife was pissed on me because we needed to jump start the car in the morning I'll summarize mods and make some pics soon.
