Slimshiesty
- Colorado
Front Brake Caliper Bolts,
I had read, but cannot confirm that the front brake caliper bolts need to be replaced as they are one time use bolts.
Is this correct?
However the rear caliper bolts can reuse?
Then, the carrier bolts need to be tightened to 147.5 ft. Lbs. of torque.
The Caliper bolts to 25.81 ft. lbs. of torque.
Also what size torx bit for the rotor mounting screw?
Is this correct?
Thanks in advance.
First brake job i have done since i owned a 69 Chevy Nova, back in 1997.
Is this correct?
Is this correct?
Thanks in advance.
