FMIC questions
Andrewbens
Modesto
2019 GTi S 6 Speed
How has it been working for you?
it’s been working great. I don’t keep AP on my dash or anything but when it’s hot outside the car still seems to have power.
mk7_drew
Queens, NY
I’m running a CTS FMIC currently, going is38 hybrid turbo, the website claims 450hp capable (which I understand you can’t really place a hp rating on an FMIC)
Would I have cooling issues with a is38 hybrid?
Anyone used this on a hybrid setup?
Hollywood0220
NW
German/Japanese
I would submit that the Volume of that IC and it's surface area is too small to cool your charge air enough using a Hybrid IS38. If you barely pushed that turbo at 21-22 you'd probably be ok - but I would surmise your aim is quite a bit above that.
StorableComa
SoCal, USA
17 GSW S FWD
CTS FMIC is reported to have 528in^3 for the core volume. Which is right around where the stock R TMIC is I believe, but surface area is pretty small. As it's not in the middle of the heat stack sandwich I'd assume you'd see better numbers, but its on the smaller side of the FMICs. The ARM FMIC claims it'll make 575hp and is slightly bigger FWIW. TMIC may be a better fit for Hybrid, but I'd defer to someone with firsthand knowledge.
El_bigote_AJ
Las Vegas
2019 GTI bunny
I’m running a treadstone trl8 front mount on my car...with a hybrid is38 at 28psi to redline, When I’m off Water/meth it’s around 15 degrees over ambient near the top end of pulls.
As a response from someone with a first hand point of reference... - my response = That CTS won’t be an issue per say but definitely won’t be optimal.
mk6'12gti
Cleveland
2018 Mk7.5 Gti
Look at getting one from LT motorsports if you want a bigger IC. Its 800 shipped for a huge vibrant fmic kit. That is the kit I went with for my Hybrid Is38
IanCH
MA
'20 GTI
Yo but there is actually no point to have that huge ic smashed up behind the bumper... Is there any space between the bumper and the front of the ic where it covers?
mk7_drew
Queens, NY
Is that the TR10 core?
mk6'12gti
Cleveland
2018 Mk7.5 Gti
No its a vibrant 12815 core. Lt used that because back when I ordered it the tr10 kit was on back order for 2 or 3 months
mk7_bk
i was gonna recommend gti jakes kit baun performance. I honestly don’t know how it stands up against big turbos but, its great for is20 and im sure its good for hybrids. Depends on your needs to be honest. If your only tracking them maybe stock location ie v2 or ams, but if you just do pulls here and there then cts would be fine
Edit: I have jakes kit :devilish: stock is20
