For GTI/A3 right?new update to boss 500 maps.
Cooling maps (fan, coolant, etc), valve lift and cam timing, exhaust cracklesWhat’s new???
Never taken any logs, but have run all of the tunes. Stage 1 was pretty decent. Stage 2 felt "grabby". Stage 3 felt pretty decent with a tendency to be a bit grabby on low load shifts.Can someone please explain the differences are between the Stage 1 and 2 TCU tunes? Been on Stg1 for awhile and wondering there is any benefit going to the Stg2.
TIA
Sorry, that was sarcasm. Eurodyne has zero documentation really to speak of lol.Thanks. I'll check the website. I didn't see anything previously and may have overlooked it.
I thought it was.....
Stage 1: stock turbo cars (lower WOT shift point)
Stage 2: Hybrid turbos (higher WOT shift points...for mine I even had a "7200rpm" version which was even higher than normal stage 2, iirc)
Stage 3: same as 2, but disables DSG based LC so you can run ECU based LC.
Could certainly be other slight diffs baked into them too. Check the detailed documentation on their website![]()
ED Stage 3 I’ve hit a 1.61 at the track launching around 5k. Last street dragy was a 1.75 launching at 4K.
Ihx475. last time I logged LC, which was forever ago it was 3-4psi on launch.What turbo do you have? Do you happen to know how much psi your at right at launch?
