What I think is most important about these graphs is that they are all on the same dyno and same car I assume (the shop R?), but comparing anything other than the area under the curve is not a fair comparison to other cars, turbos, tunes, and dynos as far as peak numbers.
For example, these graphs showing WHP, 380whp out of a IS38 on 91 octane is right at the top of the heap for output on that turbo, and those numbers are closer to cars running better fuel, W/M, secret sauce, etc. (e.g. RJRacing who trapped 126mph on a maxed IS38)
This should be common knowledge for anyone looking at dyno graphs, but peak numbers don't translate between dynos for a variety of reasons. What does translate are 1/4 mile/trap numbers, 60-130mph sprints, etc. Things that can be timed and compared based on DA.
So using any dyno sheets from the EQT dyno on their car, or other cars on the same dyno will give you a repeatable proof of performance, show improvements due to tuning or setup changes. From 380whp on an IS38 to 500whp is a 120 whp gain with their turbo, upgraded fueling and some ethanol, and that's great. However, comparing just peak numbers to competitors in completely different circumstances just isn't helpful.
Completely agree with this. But 308whp on 91 stage1, and 380whp on 91 stage2 a little strange on same dyno. Of course ambient temperature can be different, but difference in hp is too high. . Maybe 308whp was measured in awd mode, then everything looks ok
