My guess would be the Zage GTX3076 that TTH already sells, maybe they are doing their own compressor wheel design again.What’s the deets on the new turbo??
TTH Upgrade Turbo for VAG 2.0 TFSI IS-38 GTX3076 Gen. 2 (street-performance.shop)
Basically a Boss700 with DBB?My guess would be the Zage GTX3076 that TTH already sells, maybe they are doing their own compressor wheel design again.
Yeah same spec on the wheels but different rotation and housingsBasically a Boss700 with DBB?
Not much difference for sure, here is a log on my 2016 S3 on E30. I’m on 11.7s on dragy full weight.Not my car. My friend's 2018 S3 on EQT E85 OTS with the autotech upgrade. Looks like boost peaks at 27 psi to around 5500 rpm and tapers to 21ish up top. Timing tops out at 16.5 deg. His best dragy run was 11.8 @117 full weight.
https://datazap.me/u/fchantham/log-1622800540?log=0&data=17-40-45-47-48&solo=45
Not a GTX3076My guess would be the Zage GTX3076 that TTH already sells, maybe they are doing their own compressor wheel design again.
Not even a hint?
Not even a hint?
Hits target boost at 4k on the street apparently, so what like 5-600rpm later vs the XL for 100+ hp capability? There is plenty of hybrids that are capped to mid 500 that spool slower.Wonder if it can spool quicker with a built DSG box.
I used to run around e20 during the summer on my 93 Stg2 file. Definitely helps.is there any benefit of running close to an e30 blend with a 93 stage 2 map? prior to my stage 2 flash I was using JB4 running a e30ish blend after some calculations to confirm. This was very beneficial. Just not sure how this would be on a flashed tune? Obviously, a e30 tune would be the best route but I am curious if there is any negative effects as well.
