riceburner
- nice try PPNT
- MK5 Best GTI
Recently I washed mine.
Not first time.
I use aluminum foil and cover the electrical box. Wrap it around top. Also wrap alternator as best I can. Mainly cover top side.
They I snow foamed the engine and under hood. Used small horse hair detail brush to agitate. They used wet micro fiber to wash big flat spots and underside of hood. Wipe down hoses and all I can reach. They used light pressure power wash and rinsed.
They used blower to remove water. Dry with micro fiber also. Start engine and run for 5-10 min.
Let dry over night. They spray down with detailer spray or what you like. Pearl of 303 are good option. Let sit. Then wipe off extra.
This method 100% is the way to go. Some keys are the pressure washer because it will force things off your engine however it doesn't use as much water as just 'hosing it down'. Although that also means you need to be even more careful around electrical parts. I don't have a presure washer yet so i use my hose setting on 'mist' lol.
