Cuzoe
- Los Angeles
Well now if we figure that out we can make some progress on the USB-C port install (same plug, but it doesn't work).Thanks Cuzoe.
I actually came across the answer before you replied so I deleted my post.
I did just take out the MDI port in my car. It main circular portion looks near identical. But in the USB port, there's an additional part that has 2 additional pins. So not a simple plug and play. Although I am curious what each of the pins actually does
Working on that oneWell now if we figure that out we can make some progress on the USB-C port install (same plug, but it doesn't work).
Serious question because I'm curious; what would be the purpose of this other than not having OBD codes? I bought my unit from a local guy who (for lack of a better term) 'hacked it' and it hasn't given me any issues or effected the functionality of the unit. Was able to skip the whole dongle rental/scheduling a remote coder and all the costs that come with that.(Edit: I do not want to go hacked if it's avoidable)
You should be able to reuse the MDI port, you need an extra 2 pin connector and remove two pins from the outgoing 16 pin connector just forThanks Cuzoe.
Nice, I even read that post and responded, haha. And also forgot about it. Too much work for me .You should be able to reuse the MDI port, you need an extra 2 pin connector and remove two pins from the outgoing 16 pin connector just for the analog input. See here for what I did.
Bolded the purpose for you, haha. I can't sleep when there are fault codes, even ones with no functional impact.Serious question because I'm curious; what would be the purpose of this other than not having OBD codes? I bought my unit from a local guy who (for lack of a better term) 'hacked it' and it hasn't given me any issues or effected the functionality of the unit. Was able to skip the whole dongle rental/scheduling a remote coder and all the costs that come with that.
I can't tell you how many times I've referenced that page over the past couple weeks!Theres a comment here with some P/N's that might be helpful.
This may not be difficult; how many wires are there total?Well now if we figure that out we can make some progress on the USB-C port install (same plug, but it doesn't work).
Agree with the matte choice over glass. They may look a bit more modern but the gloss black trim and glass screen gets greasy/dirty real quick.I can't tell you how many times I've referenced that page over the past couple weeks!
I thought I could get away with not replacing the trim, but now see the additional screen space went vertical, which I hadn't considered. I could modify my existing, but I'm confident it'll end up looking like shit after a dremel goes to it.
Almost wish I'd done the 8" glass or gone all the way to MIB2.5 knowing that now, but I like having physical buttons and want to keep it looking "period correct."
OT, but did your TDI come with Climatronic or are you retrofitting that first and then doing the touch climate panel? Afaik there's no touch-version of the non-automatic Climatic system :\Keeping the car looking period correct is relative I think, MIB 2.5 was factory on 2019/2020 e-Golf Premium package. Of course, having added digital dash, Mk8 steering wheel touch buttons and soon touch climate control to go along with 9.2" all touch everything will be "the feng shui" in my car.
You are correct about no non-Climatronic touch controls. I am doing the half retrofit, although I will be adding both vent temp sensor and the sun sensor. I've also got a decade box setup to test some things to get it running fault free even without the flapper motors. Full climatronic retrofit is not out of the question, parts aren't crazy priced. Just don't have the time right now... 1 year old, thinking about another kiddo, and likely moving if that happens.OT, but did your TDI come with Climatronic or are you retrofitting that first and then doing the touch climate panel? Afaik there's no touch-version of the non-automatic Climatic system :\
