So I've been searching and found a few posts about people have some coding issues but their solutions haven't helped me nor did they have the same issues.
Ran DAP wiring harness and install was pretty straight forward. Got to the coding piece and can't seem to get the tails to function properly. I'm well versed in vcds so pretty sure my issue is that the coding instructions that come with the lights aren't exact for my MY; 17 GTI SE w/ lighting package (halogen tails came stock).
Symptoms after coding:
- no brake lights on tails (high mount brake light works fine)
- left turn signal works as it should (dynamic style)
- right turn signal blinks like a standard LED
- no fog light functionality; I have the updated light switch knob with rear fog option (found a post that said it needed to be coded but didn't seem to work)
- believe I have newer ODX version (ver 017002)
- with light switch set to Auto, all tails light up as they should; but still no brake lights and right turn signal blinks in non-dynamic style
- reverse lights work fine
I used obdeleven and vagcom to code but seem to get same results.
Anyone have any ideas where I should start looking??
For reference, I made coding changes to channels 20,21,23,24 - also tried 26 and 27 trying to get rear fog to work.
Appreciate any input!
-Rich
-Rich
