What lubricant did you use in the pistons seals, if any?
Also, so some abs panic stops. It'll get any air trapped in the abs system out.
Are you doing 30 psi bleed?
As the garage installed them I don't know what if any lubricant was used on the seals.
After my initial post I searched the post more and turned the hydrolic brake assistance off using OBD11 then took it for a drive and did engaged the ABS. I didn't feel much of a difference after this but imagine I will need to bleed again to notice the difference?
I was bleeding them at 30psi but I am not 100% certain I did the order correctly. As I'm based in the UK I have RHD and the manual I have says for RHD start with the front right brake.
I think I'm going to try and bleed them again when I get time at the start of next week and tap the caliper with a spanner at the same time as I've read somewhere that helps work the air out?
Since I bleed them it's slightly better but still not quite right.
