"Stopping better" has got to be better defined. There's stopping distance when cold, when hot, resistance to overheating/boiling, pedal firmness, consistency, and more.
Under most street conditions, almost any braking system ought to be able to engage ABS. Under those conditions, it is the tire, not the brake system, that limits braking distance. If you haven't engaged ABS, then you haven't met your brake system's limits. And then there is pad material, with different coefficients of friction and optimal temperature ranges. A trackpad is less effective when it's cold but can be very sensitive when hot and vice versa for street pads. IMO, pad material and operating temperature affects feel more than caliper design. A pad material with good coefficient of friction at your operating temps should give a good feel.
Pedal travel has a different set of influencers.
- As discussed before, a surprising one is whether a caliper keeps its pads in close contact with the rotor. From what I've seen, our PP rear calipers do a good job of that with their relatively stiff springs and the ratcheting effect of the hand brake (if that's how that works). And this is why people recommend red grease for Macan calipers - so that piston seal stiction does not slightly retract the pads after every brake application. I've seen cases where the pads can be slightly wiggled back and forth between the caliper pistons and rotor. That will cause pedal travel.
- Another influencer is aged brake fluid - not aged in time but in temperature. Heat degrades fluid even before boiling. In track conditions, flushing the calipers periodically helps.
- And one more possibility is brake hose material. Some upgrade to stainless steel hoses but I'm not convinced this makes much difference in pedal travel/feel.
To me, the benefits of aftermarket calipers, whether Macan or others, are applicable to track use: a wider selection of pad material, more resistance to over heating fluid, lower weight. I'm not at all convinced there's any perceptible difference for street use.
Bern
