If still given same feel, try this method.Did the bleeding yesterday 30psi pressure LF RF LR RR i soend more than one liter of break fluid flush it and everything. Still the exactly same feel , i mean its not bad but it takes 0,5inch to start feeling the brake and than it brakes fenomenal, When u pish it hard its better than oem 100% but on oem brakes you can feel them braking right when u touch break pedal, thisone take 0,5inch +/-.
When u have car in sport and brake hard car is downshifting harder with this braks which i like to be honest because car thinks ur breaking harder/pushing kore pedal.
Go get some sticky pad or double sided tape. Im using 3M 55236 HiTemp double sided tape. Stick at the back of your brake pad. Make sure you clean both the back of the brake pad and the piston before you reinstall back with the double sided tape.
Do let me know if this work for you.
PS* you don't need to re-bleed again after the double sided tape apply.
