nono0044
Toronto
Just a quick +1 for this. My OE Brembo seals melted after 7 track days last year. These high temp ones will save you. Plus, the guys that sell them (Ohio Performance Solutions) are just a group of 4 track addicted buddies that decided to start this little company to help them and other addicts put high quality brake seals on their cars at a REAL GOOD price.
I think it comes out to around $80 bucks for enough to cover all 8 pistons
I'll pick some up in the next couple of weeks and report back. Just any FYI to those in the thread, Macan calipers use 42mm pistons all the way around.
Here's the link to the 42mm ones. I'm probably going to grab a set at the end of this summer. Might as well toast the stock boots first :p:
https://www.ohioperformancesolution...individual-pressure-seal-high-temp-dust-boots
Update: Unfortunately they don't fit, see here: https://www.golfmk7.com/forums/inde...can-brembo-upgrade-thread.371028/post-7436661
Dubstro
Texas
2016 2dr GTI 6MT
Thanks! Hope to see finished product.
All the great info/testing in this thread is very much appreciated! I went with the Macan calipers, MK6R rotors and akebono Q5 pads. Just waiting to hear back on lines.
MiamiBourne
South Florida
2016 6MT Golf R Oryx
Full info regarding that group buy I mentioned. We're finding out if there's further discounting after the 5 person minimum threshold.
If you're looking to use the Macan calipers to track, these would be a great option.
What is the regular price on these? I haven't heard anyone use these on this forum or VWVortex but have seen these mentioned on the VWROC forums.
nono0044
Toronto
Regular price per the site is $469.06 + whatever the shipping cost to you would be.
Makes sense as most users on VWROC are UK based and so is MTEC
There's some pics on first page, if that's what you mean, but you don't have to ask me twice to pimp my car.
Dubstro
Texas
2016 2dr GTI 6MT
LOL, just meant I wanted to see Charlotte.:R's calipers DIY painted gloss black with decal. But, your powder coated red calipers look awesome. Don't see rse16's often but that's really nice combo with the white GTI. Are you stock ride height?
EpicTech
Houston
MK7 GTI 6sp w/PP
Is there a parts list for us PP guys that includes everything needed for the swap?w I got the caliper part #s but what else is needed to buy at the dealer so that I can do the swap?
yirayira
Chicago, IL
2015 GTI SE
Great idea and I would recommend swapping to higher temp boots before any track work. I suspect leaving the oem seals will be fine but once the boots fail you should do a full rebuild.
From my experience with 986 Brembos even titanium shims only slowed down but did not stop the oe Centric dust boots from melting. (312mm standard rotors, race fluid, race compound pads, no heat shields, and RS3 deflectors) Towards the end I was having to rebuild after every track weekend. A rebuild is pretty straight forward after the first time but it's messy, time consuming, and the parts aren't free ?
Yes the Macan setup has a higher heat capacity but replacing just the boots now should save time and it is one less thing to go wrong at a track day ? I'll report back on my experiences with wear and tear in post #2
I'm assume a non-PP car, correct? I did one track day in my 2018 S and xds absolutely cooked the brakes, seals, melted center caps, and probably took years of life off the bears due to heat. Did you have xds off or on? Makes a massive difference in non-PP cars if you didn't add a LSD.
No, I'm on APR springs, Eurosport Camber kit and H&R 26mm rear sway. The car is fantastic on this setup, especially with all the OBD11 tweaks.
nono0044
Toronto
All on the first post. There's nothing you need from the dealer unless you plan on sourcing your pads and rotors from the dealer.
yirayira
Chicago, IL
2015 GTI SE
Non-performance package with an aftermarket torsen lsd from Mfactory. Both XDS+ and TC were fully off. XDS+, even on weak, was causing the front end to dig during high speed corners. Side note Cobb TC on sport with no XDS+ is my current track setup
