Took me over two weeks to get this project done, but I just wanted to share my experience doing this brake upgrade (my first time ever doing a big brake upgrade):
1. High temp rattle can paint (primer + base + clear + ceramic) came out not half bad, but it's soft as cookie dough and paper thin. I've already nicked the paint by the bleeder valves
2. Make sure to bleed the system in the correct order (LF -> RF -> LR -> RR), outer bleeder valve -> inner bleeder vavle, and pressurize your power bleeder up to approx. 30psi if you are using one. I first bled the system like every other car starting with the brake caliper farthest from the MC and only used about 20 psi in my power bleeder. That first drive was not confidence inspiring. After correctly bleeding the system and using the correct amount of PSI in my power bleeder, the brakes feel awesome!
@GTIfan99 Can you add this brake bleed procedure as note in the OP? It would be very helpful for noobs like myself.
3. Use
Centric 105-16630 pads for those of us that have a brake wear sensor. These are great daily driver pads.
@GTIfan99 Can you add this brake pad part # the OP as well? It took me a while to hunt these down.
4. If you are using stainless steel lines for Techna-Fit, make sure to screw in the caliper side first because you have to rotate the entire line as you screw it in.
5. I hammered the edges of my stock brake dust shield flat so it wouldn't rub against my new 345mm rotors.
6. If you plan on disassembling this caliper, getting the pistons out was a PIA even with a blow gun. One piston would come out, but now you have the other piston still stuck in the caliper. Maybe this is because these are brand new calipers with no fluid inside them to evenly distribute the air pressure?
I almost regret not just buying a big brake kit like the Stoptech ST40, but I did learn a lot more about brakes than I knew before. Thanks to you all for the very helpful info in this thread!
View attachment 220530 View attachment 220531 View attachment 220532 View attachment 220533 View attachment 220534 View attachment 220535
View attachment 220537 View attachment 220538
