Yeah, as Zumble said, map 0. Set your map 6 to all zero everywhere other than boost safety. Put that at like 25. I recently saw a guy trip the boost safety while on map 0. There is a glitch in firmware 8.4 that flipped it to map 4. I reported it to George. Map 4 used to he the default map for 0 boost pass through. It's now an additive map designed for the R/S3. Could have been dangerous. I doubt they fixed it yet because it's in that firmware. I have had other issues with that firmware as well, but I guess the majority didn't so they didn't give a shit. Defaulting to map 4 is a major issue though so they need to fix that and you need to be careful
You'll likely want to be careful running maps 1-4 after stacking also. You can pretty much only safely run a custom map 6 now.
Set to map 0 before flash (probably not really needed), FOL 0, Fuel Bias 0 down the whole column.
Going to set to map 0 with FOL and fuel bias and do u think i should remove the whole JB4 as i need to monitor it. Will i be able to log as well?
Hi guys, I recently upgraded my IS12 turbo to IS20, which JB4 map 6 settings recommend me to try with 92 octane.
I also have downpipe 3" and VWRacing R600 intake.
The firmware version of my JB4 is 60/85//5
Thanks
Here are a bunch that someone put together. I would say with 92, start with one of the lower boost target ones and log. Also log a map 0 first for baseline timingHi guys, I recently upgraded my IS12 turbo to IS20, which JB4 map 6 settings recommend me to try with 92 octane.
Thanks
I know. I just ran a log today of the new file on the tune. 22 psi at 6,500 on 93.
Yes, but as you know, it's cold. I'm selling the jb4 and the meth kit. I'll use some of those funds towards the IntercoolerDamn... It's gonna be like 24 psi at 6500 when it's hot out. Still stock ic???
Yesterday's were about a 20 degree rise. Went from 49 to 69 on one and 51 to 71 on another. So in the summer it will be bad. Intercooler is definitely needed.How much of a temp difference are you currently seeing from the start of your pull to the end of your pull?
