Burger Tuning JB4 Golf 1.8TSI MQB specific information thread
ZuMBLe
NY
Alltrack 6MT
You'll likely want to be careful running maps 1-4 after stacking also. You can pretty much only safely run a custom map 6 now.
Teo1.8t
Hey guys I got these codes today what do they mean
2020-01-29 16_40_18:
3BD6 No Description Found
5A56 No Description Found
0000 No Description Found
Slick99
Karachi, Pak
Yeah, as Zumble said, map 0. Set your map 6 to all zero everywhere other than boost safety. Put that at like 25. I recently saw a guy trip the boost safety while on map 0. There is a glitch in firmware 8.4 that flipped it to map 4. I reported it to George. Map 4 used to he the default map for 0 boost pass through. It's now an additive map designed for the R/S3. Could have been dangerous. I doubt they fixed it yet because it's in that firmware. I have had other issues with that firmware as well, but I guess the majority didn't so they didn't give a shit. Defaulting to map 4 is a major issue though so they need to fix that and you need to be careful
i thought map4 is just like map3 for FL A/S3 or R with 7spd dsg, will set everythig to 0 before going to flash. New beta update firmware has been released as well might update JB4 as well but i m gonna use it for monitoring after flash. Thanks for info let hope how the car react with flash tune map.
Slick99
Karachi, Pak
yes would be careful wont touch any maps on jb4, custom map 6 if theres room for more fueling and maybe for IS20 in future.
Slick99
Karachi, Pak
Set to map 0 before flash (probably not really needed), FOL 0, Fuel Bias 0 down the whole column.
Going to set to map 0 with FOL and fuel bias and do u think i should remove the whole JB4 as i need to monitor it. Will i be able to log as well?
ZuMBLe
NY
Alltrack 6MT
I log my tune just fine in map 0. Log your new tune and post it up! A lot of people have no idea what their Unitronic/APR/IE/etc OTS tunes look like. With the JB4, you can get a pretty good idea what's going on. You can also leave the JB4 for valet mode.
gio18
MX
Hi guys, I recently upgraded my IS12 turbo to IS20, which JB4 map 6 settings recommend me to try with 92 octane.
I also have downpipe 3" and VWRacing R600 intake.
The firmware version of my JB4 is 60/85//5
Thanks
ZuMBLe
NY
Alltrack 6MT
Thanks
I think there is enough information in this thread that you can run a search on it and get great results. You'll find some settings posted and some datazap logs. Use the "target" field of the logs in order to figure out the setting that was used.
TwinDad
Fort Lee, NJ
Thanks
Here are a bunch that someone put together. I would say with 92, start with one of the lower boost target ones and log. Also log a map 0 first for baseline timing
ZuMBLe
NY
Alltrack 6MT
Those boost numbers are so little and cute.... ;)
Wish we could make that spreadsheet a sticky.
ZuMBLe
NY
Alltrack 6MT
Yes, but as you know, it's cold. I'm selling the jb4 and the meth kit. I'll use some of those funds towards the Intercooler
How much of a temp difference are you currently seeing from the start of your pull to the end of your pull?
TwinDad
Fort Lee, NJ
Yesterday's were about a 20 degree rise. Went from 49 to 69 on one and 51 to 71 on another. So in the summer it will be bad. Intercooler is definitely needed.
