MeltedSolid
- San Francisco Bay Area
- '15 Golf, e36 328i
Too lean up top.
True, maybe add a bit of FOL
Too lean up top.
http://www.datazap.me/u/crees9/jb4-is12-18-psi-94-octane?log=0&data=1-4
2 logs need to lower abit at 5500 i think to around 15 PSI.
logs have been sent to george to fine tune this a bit more.
I'm going to try this tomorrow,
1500 12
2000 13
2500 14
3000 15
3500 16
4000 18
4500 18
5000 17
5500 15
6000 15
6500 14
7000 13
or whatever george sends me to fix lol
ill follow your advice and relog maybe not today though. also I'm running 94 octane that contains %10 ethanol from gas station. also stock downpipe, all my mods are in my sig.Looks really good. Still stock downpipe? Right? What fuel are you using? The IS12 doesn't like as much boost from 4,500 up. Especially on the stock pipe. You can probably make your 3,500 18 and then lower the 4,500 to 17.5 see if you get any more advance in ign1. If you gain 2 or more degrees, it's worth it
Here's an interesting log to me. Something weird is happening? I'll let it speak for itself..
http://www.datazap.me/u/17s/gentle-map-6?log=0&data=1-2-3-4-11-14-18-25-27-28-29
I have a better example here. It is happening consistently for me.
The lean spikes toward the bottom of the pull are what I'm referring to.
http://www.datazap.me/u/17s/lean-spikes-0?log=0&data=1-2-3-4-11-14-18-25-26-27-28
Random spikes are fine. They are glitches in the logging. The Ecu can't react, change and then read that quickly. The only time you need to worry about a lean condition is if you see it go 15 or higher for more than a few hundred rpms which would be like 4+ cells in a row. When you see it spike up, but it's good right before and right after, it's ok
sorry whats considered lean? which value tells you AFR? also what values are deemed safe for AFR 13.2-13.7? what happens if its like 11?
