Golfs everyday
- USA
If I was worried I'd keep the stock plastic pan and get a thick aluminum skid plate.
Under engine cover
Check updated post above yours.
Below is a link to the one I have
US $128.70 35% Off | RKAC car styling For VW golf 7 Plastic engine guard 2012-2015 For Golf mk7 Engine skid plate fender alloy steel engine guard
https://s.click.aliexpress.com/e/bBodOOYg
How's the fitment of this cover?
Is this the same as the OEM skid tray, or more like the aerodynamic tray that Golfdave was talking about in his DIY?
Golfdave where can you buy one as I live in Canada and don't see any listed here.I think you will find those covers with the hatchs for access are thin plastic & just an aero cover...the VW made GRP (Kevlar reinforced) full engine bay cover is a proper skid tray & is quiet compared to an aftermarket aluminium skid tray when stones hit it...
I still haven't seen anything as well designed as the VW OEM skid tray......& mines still good 4yrs on...
Will this one fit a 2019 even though it says for up to a 2015.
https://www.aliexpress.com/item/RKA...pm=a2g0s.13010208.99999999.259.5ff53c00uoaY3k
This one might do the trick
https://www.aliexpress.com/item/BIN...07-4184-83c6-d9c1af5f38a7&transAbTest=ae803_3
Why do people link to absolute junk???
Did you not see the pictures when you scroll down of them proving how strong the "plastic steel" is by bending it 180deg back on itself with their foot..??!!…
The last thing you want is a undertray that is that flexible…..even the OEM factory thin aero tray (VW call it sound insulation for diesel engines)..is stiffer..!!
Why ??...because a flexible tray will create undue vibrations & noise when the air passes over it....& more so the faster you go..thats why the OEM one has stiffening ribs...
If you want impact protection you need something SOLID....& that is MOUNTED SOLID....you also want something which will not amplify the sounds of stones hitting it either...so something made of strong plastic..or hang on maybe GRP with Kevlar in it??..I wonder if there is one made by VW for countries where they have rough roads???
If the OP wants to protect the oil pan properly just fit the item VW made for the car..the skid tray as I did in my how to guide....anything else is a waste of time IMHO...
BS Dave.
It is not that flexible.
Once bolted in it does not flex much.
Kevlar reinforcement strands yes.
It ain't bullet proof.
We do not all have to follow the same line.
I love my POS.
