Diggs24
- de plains! de plains!
- 2015 GTI
There's nothing fun about your car sounding like shit. The MK7 sounds like crap so why make it louder?
Fun? They’re annoying at best.
Thanks for you opinion.
What?Just like yours on the lack of fun breeds immaturity. Interesting concept.
But happy to help.
Have you found something out?The afr was concerning to me so I already did move to map 0, bought this jb4 second hand but I'll email George, but I did find values in the WMI tab changed them all to 0s and unchecked all boxes. Will do some map 0 logs later in the week and go from there.
I have a 335 with BMW's performance exhaust and it pops under certain circumstances but it's easy to drive with no pops. It's a manual so if you lift the throttle abruptly above 2500 rpm -like decel to a light, it will pop and burble for a few seconds. There's a subtle burble at startup too. It's pretty much perfect sounding. None of that constant sharp pop and crackle people post vids of....My R has APR's exhaust and while I'm not quite in Digg's camp where I think the car sounds like crap, even with the exhaust it's pretty mediocre. Good from outside the car, ok from the driver's seat and strangely deep, loud and annoying in the back seat. Not sure why exhaust tuners go for that big/deep sound when that's neither the characteristic of the car or motor....
See you have the same issue as I. Stuck Trim value and then the car goes Lean.
The only way I could fix this was to increase FOL or lower the boost, but then I get the Fuel Rail Pressure CEL. I don’t know why this is Happening
Sorry for the late reply but under the wmi tab there were settings turned on for meth injection causing the lean afrs since I was not using meth. I bought my jb4 second hand thus the settings being changedHave you found something out?
Thanks!
Good to know! I always thought Esso was top tier, Ill be sure to run PC94. Thanks for the heads up!Try to keep to using the Petro 94. Esso isn't top tier. Not sure if you care about that, but it's highly recommended using top tier gas in these cars.
