GolfRchris
- Croydon
- Golf R
If I pop the bearing out this is how it looks. It’s just a shadow you saw ( about the tab tab notch notch. Deceiving I know.It’s definitely right from what I believe unless someone can tell me. There is only 1 cut out on the bearing and the notch sits in it.
ive just wound down the spring to the bottom and if I rotate the bearing 180 the bearing doesn’t sit right. So that can only be the position.
also the spring wouldn’t sit right after that would it.
