I wish an aftermarket company would pick this idea up. Would buy this set-up right now. Grill w/ different lighting options, + harness.I made some cups I 3D printed out of ABS, and then glued into the lower grill; I got some Toyota truck generic fog lamp housings that slip in from the back and use a yellow LED bulb. I did this project mostly as an homage to older rally cars, but they work pretty well too! Up close it looks factory, and doesn't block the flow.
Looks great.I wish an aftermarket company would pick this idea up. Would buy this set-up right now. Grill w/ different lighting options, + harness.
There is such limited mounting points for the Alltrack unless you want lights floating out front of your bumper.
Love this.
I wantLooks great.
I'd like to see an "old school" rally lighting solution with lights above the bumper but not sticking away - kind of like this
I've got a broken Hella in a box somewhere. I'll have to find it and do a mock-upI want
Anybody have a broken Alltrack grill they don't need? I think you could recess the lights about an inch or so into the grill without interfering with the hood operation.I've got a broken Hella in a box somewhere. I'll have to find it and do a mock-up
Not really - perhaps I explaned it wrong - the grill angles back by about an inch or so, so by insetting the lights into the grill, they move farther back from the front of the bumper. The actual light would be partially above the hood and directly in front of it.They would have to be pretty small because the honeycomb portion is only about 2.25"
Personally, my ideal setup would be to relocate my front license plate to the tow-hook spot, and use a light bar to cover all of the license plate bracket holes. I'm not sure if there's any light bars that would suit that position, in terms of aerodynamics and mounting though..In all honesty, all I can think of, short of molding in some hood rally light, is to get a light bar and affix it to my roof rack. I simply cannot find a solution for additional lights. I can throw them behind the lower grill, but it would block my FMIC, so no thanks
Some fogs hidden behind the lower grill. Not legal to use them on public roads of course, but i do every once in a while.
