Not enabled from factory.
After coding with VCDS you'll find it in the menue (Car > windows), then
you can activate rain closing each time you need it. Since it draws some
power/current, it should not be active permanently, as you don't want a
dead battery after two weeks standing in an airport parking lot.
From what I remember it's only possible up to 2015, not on 2016 models.
you would really leave your car at the airport with the windows opens for two weeks??![]()
I had a Mazda with a sunroof years ago. It was a clear day without a cloud in the sky. We stopped in a furniture store for 15 minutes. I left the sunroof open. When we came out the seats were soaked. That freak rain did a great job. So if you use your sunroof or like to leave your windows down, it's not a bad feature to have. Like was stated, (try) to remember to shut it off if your car sits idle for days at a time.
It is not meant to be left on for a long period of time, in the real world nobody would do that anyway. I use mine all the time with no problems and it works like a charm.
Sorry, I'm just not seeing it guys. When do you turn yours on then? When you are expecting it to rain? Why not just put your windows up if that is the case?
