johnnloki
- Bowmanville ON
The University of Texas study costs more than $100.
I'll pay $1,200 to anyone who will build me a brand new GTI.
Yep, I read through that. Like to get many opinions.
You really need to chill. Like your IATs would be with a turbo blanket installed!
Did you look at the link I posted from UoT Austin? That should have enough data to keep you happy for a bit, even though it's not in a GTI.
This might satisfy some folks curiosities:
https://docs.google.com/file/d/0B1DKgBxqE0JEME5wQ1pIc1N5dU0/edit?pli=1
TL;DR: Increases exhaust temp, reduces spool time, negligible increases in oil temps at the turbo.
This was a test done on a big ass diesel engine, with a lean to determine the blankets value for EGR and aftertreatment method efficiencies (which are helped by higher EGTs) as well, but it's still valid.
Also this: https://forums.vwvortex.com/showthread.php?7452545-Mxrider9239-Mk7-Golf-R-Build/page3
So do you not see merit at all to a turbo blanket from your vast previous research, or does a GTI somehow constitute a retest because it's not just an air pump like the other engines turbo blankets have been tested on?Yes, I read that article 5 years ago when I was testing a turbo blanket manufactured by Thermal Zero.
Here's a couple other good reads on the topic:
Impact of Turbocharger Non-Adiabatic Operation on Engine Volumetric Efficiency and Turbo Lag (Shaaban, Seume) International Journal of Rotating Machinery December 2011
Heat Losses from the Turbine of a Turbocharged SI-Engine - Measurements and Simulation (Westin, Rosenqvist, Erik Angstrom) – Modeling of Spark Ignition Engines, March 2004
$100 will save me some effort if somebody else will undertake testing the product.
Thank you for the resource. Tldr: blankets are good.
From a science standpoint its not 1:1 so i’ll take it with a grain of salt but result conclude the turbo blanket works. Like all things.... i figure they wouldnt sell them if they were bad for your car hehe
$100 to the person who proves that it improves spool up or lowers IATs on the GTI.
Stipulations: Proof IS NOT "I installed the blanket and saw my IATs drop", nor is it "my turbo spools faster now, I know my car and I can tell if there is a change, it's faster now." Proof IS multiple data logs taken before and after the blanket install under the same conditions where a distinct, consistent, change is observed in the data.
Don't hold back now. Tell us how you really feel.You are drawing the wrong conclusion about what I have said.
But what if they're made of real actual stick on carbon fiber? Can't argue with the weight savings there.A Forge turbo blanket will net more benefit for $50 than some folks paying $150+ for paddle extensions.
just sayin' ....
