CaptainRatty
- Winston-Salem, NC
- MK7 GTI
Woah! left this thread for 12 hours and came back to....
Just to let everyone know who's interested in buying this thing, if you have the Apr charge pipes it will not work. There is a gap of around 4-5 inches and the diameter is different. I assume any aftermarket charge pipes wouldn't work either. Really kinda of upset Apr didn't state that in the first place. You'd think being as it's an apr charge pipe they would want it to work with their Apr turbo. Im a tech at an Apr dealer and I still can't believe how little information and support they provide to us sometime.
imagine thinking you need 2-step colder race plugs to uNlOcK tHe PoWeR of your 48mm turbo on pump gas...
I think we're going to start seeing a lot of this.
I really hope it gets worked out. On paper, the kit is phenomenal for the price. Even if it falls short of 400hp, it still looks like a good value for GTI folk who either are stock, or at a simple stage 1. R folk, or folks who may have swapped over from IS38 GTI's (I know of at least two, and one of them has been pretty vocal about their disappointment), I hope it ends up living up to what was advertised so it doesn't end up being a waste.
Really looking forwards to @riceburner's feedback once it gets flashed, I haven't heard of anyone else doing the fueling upgrades on an R yet.
Installed this for @riceburner today.
The instructions Apr gave for the low pressure fuel pump are terrible. Literally incorrect and advised to connect the wrong wires to the pump. Luckily the error was spotted but if we had followed apr's guide it wouldn't start and we'd be pulling the pump again to troubleshoot. The pictures in the guide don't match the pump and it's just very poorly written with all kinds of nonsense and spelling mistakes. Do better @Arin@APR I see a lot of complaints coming your way if the guide isn't fixed.
Only 22 psi max? I know boost isn't everything when making power, but that is certainly on the lower end. I have high doubts this kit will reach 400whp at those boost levels. Something seems off...
I still can't believe APR doesn't allow logging, monitoring, or switching of maps without a dealer. Working with a friend to work out some kinks in his 2015 R which has been APR stage 2 since it rolled off the lot. I'd love to be able to flash it back to stock until the car is running as it should, but nooooo....uhggg
These results are significantly slower than my own testing, and other customers. Surely there is a reason, and we'll get to the bottom of it.So went out early this morning because yesterday it was raining on and off. I did 2 60-130 runs using Diggs recommendations. I also did a 1/4 mile run to see what the trap speed was because that tells a story also. Sadly nothing was that impressive. Obviously the et is crap because the car spun as seen in the graph but trap speed doesn’t really lie. Not really sure what’s up but just doesn’t seem right. I did double check my Wastegate and it’s at 3.84 at idle using the is20 gate. I’m lost.
I’ve sent logs and the same dragy screenshots to Kal. The car is consistent so I doubt it’s heat related. I have yet to see another GLI running this kit with numbers so not much to compare.These results are significantly slower than my own testing, and other customers. Surely there is a reason, and we'll get to the bottom of it.
Arin you want my VIN? Sorry don’t know if you were talking to someone elseI'm aware of two customers who are unhappy (Bran and Larry). Are there others? I'd like to get the ECU information down to engineering so we can scrutinize the files to see if there's a pattern. Please PM me your vin so I can check further.
