I made that point just a couple of posts above yours:
It would also be useful to consider what is going to take place on the vehicle. The engine will pull the same amount of air from any of these intakes. What ends up being different amongst the intakes is the amount of pressure drop that the intake causes. The restriction prior to the compressor of different intakes varies corresponding to the air flow ranking, an intake that will flow more at a fixed depression will cause less pressure drop then one that can flow less, when they are operating at the same flow rate.
It is two sides of the same coin, I just test to a fixed depression because it is easier to do than a fixed airflow.
