Wastegate13
- SoFla
Nope no negative camber up front at all, and actually very little on the rear. I will be however running more negative camber on the rear next week so that I can go a bit lower.
This supports my theory that there is a lot more room under the fenders of the MK7 vs the MK6. Are you rolled up front or just the top screw removed? The set up I'm looking at is actually a little less aggressive than yours and its hard to tell but I believe you are lower as well.
