Tommyjohn342
- Chicago
- 2017 Golf GTI
And can ppl still stop insisting it's the cabin filter. Seriously it is NOT the cabin filter...
No it can't be that because the blower changes speeds consitantly without fail when I select the speed. There is no loss of power to the motor, fuse is still good. It really boils down to the air flow stops coming out of the vents. That's all. I can reset it by turning off the air for a few mins and turning it back on. It eventually stops airflow again tho.
Sounds like you have to get Your blower motor Checked maybe needs replacement Or maybe the connection is faultyAnyone have issues with AC not blowing strong enough? It blew at full power for about a minute on setting 6 but after it just died and felt like it’s blowing at a 1. It’s cold though. Happened to me twice now.
Yeah it's definitely not the blower. No sounds. I can see it spinning just fine. Today I was running tests and I think it might be Air Distribution Flap. Does anyone know how to change the values for the Air Distribution Flap using long coding? I've heard ppl have success with this but can't find out how to adapt it.Sounds like you have to get Your blower motor Checked maybe needs replacement Or maybe the connection is faulty
I might try replacing the AC pressure switch as a last resort. Based on what they have said I still don't believe mine is because of a bad AC pressure switch.
I'm still having the same issue. Might just bring it in to the garage this week. I can hear the blower motor blowing hard but it's not coming out the vents.I might try replacing the AC pressure switch as a last resort. Based on what they have said I still don't believe mine is because of a bad AC pressure switch.
Do you have an APR tune?
As I said, you should contact professionals. This problem requires qualitative service bc it has a lot of nuances that must be considered. Once I've had the similar problem, when the AC vents in my BMW M5 didn't work. I spent hours every day in my car suffering from unbearable heat. That is always like a hell to me, when air conditioning is out of service. The same situation happened to me when i moved to Singapore. I almost fainted when I spent a couple of hours in a stuffy room without conditioning. I set AC all over my house and now I enjoy this sweet coolness even when outside weather leaves much to be desired. I try to maintain my AC in the best condition. Thanks God, I came across these guys, who did the high-quality work in a very affordable price Here, I hope they will help you too https://www.airconservicing.org/why-choose-us/
