erikweber321
I found a shop about an hour away that will do it for me. I'll keep updatingPlease do take before and after images and report back.
Sent from my Pixel XL using Tapatalk
Berrymans B12? I think i may have some of that, hmm...
Good old old schoolers...
Without a oil analysis you will not be able to tell one way or another.
I've been doing changes every 7.5k miles since all the research I've done points to 10k miles being just fine for those that don't thrash on their cars.
If you're hard on your car (several Italian tune UPS on every trip) bump it down to 7500. If you regularly take the car to track events then 5k or so. If it's a track only car change it more often than that.
Again, get a oil analysis to know for sure.
VWR has one of the best oil catch cans available. Though not for the reason that you would generally buy one. With a stage 1 or higher car it becomes necessary to pick one up. If you track the car (especially road course tracks) it's mandatory to have it.
Reason why:
The VWR Oil Catch Can System also takes the track & motorsport experience of these engines to correct the problem of oil build-up in the top of the engine during high-G braking.
I just sprayed 3 cans of crc and now my engine farts black smoke. Map sensor shit the bed, and my turbo blade is micro polished. .
Why not spray the entire 6-pack while you were at it? Geez, 3 cans??? Sometimes more in not better.
How did you administered it? The safest way is to unplug and remove MAP sensor and spray it directly into the manifold. I bet you did it trough the air intake, didn't you?
Quick update, sorry no picture to post at the moment, although I did take some pics. I was able to get an endoscopic camera close to the #3 intake valves, through the MAP sensor bung, but was not abke to get a full view. However, I could see enough to know that at 3000mi on the odometer, there is definitely already a light buildup of crud. Probably wouldn't have made it out with the grainy camera image, except for the cleaned or cleaner zone up on the valve stem... Although, the valves seemed closed? Anyway, I'm pretty sure it was some buildup. I guess there is some kind of swirl control flap in the intake runner? I couldn't get past it with the camera...
Pretty convinced that, assuming solvents can help a lot, I'll tap or drill the molded port-injector blank ports. Probably can't be done with manifold in place...
