Same here. After seeing what
@xXDavidCXx has done in STH using the larger FSB, I’m all ears and willing to experiment in GS.
I realized now that throwing the biggest rear sway bar I could find at what I perceived as the problem wasn’t the answer. I did that before I even got decent tires, an alignment, or even trying different tire pressures. I love the feel of it, but did I make the car slower?
What is a solid plan for GS? (assume there is testing and turning at each step)
- Full alignment with max front camber (~.9 degress), 0 or 1/8th rear toe out (minimal camber)
- Also play with tire pressures. Dependent on wheel/tires used, type of surface.
- Koni Yellow Sport struts
- 034 23.8mm adjustable front sway bar
- Move to more aggressive rear toe out to balance additional front stiffness, get more rotation
Is this a GS version of David’s STH recipe?
Questions I’m asking myself.
Is GS too frustrating due to fighting the stability control nannies that cannot be disabled under the current rules? How would this impact daily driving, especially in rain/snow?
