Need some help.
So had an APR dealer install a used is20 into my 2018 GSW (45K miles). Turbo is L revision with ~40K miles per seller.
Car ran great for a few days, then EPC light came on when going up hill @2500 RPM in 6th gear. Power cycling removed the light. If would come back on sporadically under same condition until one day, the check engine light also came on. Took it back to installing dealer and the following fault code was read:
P00AF00 - Turbocharger/supercharger boot control 'A' Module. Performance (static Fault) - MIL ON
Dealer said I had a failed wastegate so they swapped in my IS12 wastegate.
A few days later, same thing. EPC w/ check engine light.
Called APR and they said nothing can be done...its a wastegate issue and the internal gears fail.
I can't be dropping hundreds of dollars every few weeks to have my car run...obviously.
Any suggestions?
Any suggestions?
