tigeo
- Richmond, VA area
So one more time - why are your oil temps so low? Which oil cooler do you have? I've read up on the Racingline one and it sounds like it drops it some but not a ton. I believe you can also run less coolant/more water which helps with the oil heat exchanger.I have a 215F thermostat internals kit that I can swap into my thermostat. Got it it for this possibility. It will help for the street. Not sure how it would impact track temps. Hopefully I have sufficient headroom built into my cooling system that it doesn’t impact track temps negatively.
