normcaldwell
- Denver, Colorado
Looks like Bridgestone is bringing the RE-71RS to the U.S. Not much available yet.
Bridgestone Potenza RE-71RS (tirerack.com)
have you tried the v730s yet? how much pressure are you running hot on the R?255/35/18 on a 9” wheel seems to be the sweet spot IMO, 25” tall which leaves good fender liner clearance when running additional caster up front. The section width is normally around 10 - 10.4” depending on tire.
I have some Cup 2’s 245/40/18 (25.7” height) and they were rubbing my fender liners on very hard compression. It seems most 245’s run very tall making you have to run your car a tad higher than with the 255’s especially with extra front caster.
I’m trying out the V730’s in a 255/35/18 coming from the RE71R which has the same specs for the first time in a few weeks at Auto Club Speedway. Should be a good test, weather should be in the low 80’s unless I get lucky with cooler weather.
My friend just ordered these for his Cayman. Delivery was just pushed out to August.Looks like Bridgestone is bringing the RE-71RS to the U.S. Not much available yet.
I've been running 35 hot in the GTI.have you tried the v730s yet? how much pressure are you running hot on the R?
I use to run the RE71R at 35 hot so I was going to try the same as GTIfan99 suggested. Sidewalls seem decently stiff on the V730 so I’m anticipating that working fine. I have my event next weekend so I’ll share my results/opinionhave you tried the v730s yet? how much pressure are you running hot on the R?
I used to run Rze71R's too and I actually like the V730 sidewall characteristics better.I use to run the RE71R at 35 hot so I was going to try the same as GTIfan99 suggested. Sidewalls seem decently stiff on the V730 so I’m anticipating that working fine. I have my event next weekend so I’ll share my results/opinion
Thanks, I'll give that a shot. First event on mine tomorrow (245/40/18 on 18x9).I use to run the RE71R at 35 hot so I was going to try the same as GTIfan99 suggested. Sidewalls seem decently stiff on the V730 so I’m anticipating that working fine. I have my event next weekend so I’ll share my results/opinion
Nice, good luckThanks, I'll give that a shot. First event on mine tomorrow (245/40/18 on 18x9).
Thanks for feedback!I used to run Rze71R's too and I actually like the V730 sidewall characteristics better.
It's not an issue on the lighter RWD cars I used to drive, or even with 245 40 17, not the re in 255 40 17 needed 38+ or the stiff sidewalls would do this weird buckling sensation and would understeer on the GTI.
The V730 have a stiff sidewall, but it has enough compliance that it's rollover behavior is smooth.
I ran 5 sets of re's in 245 40 17 without issue, both sets of 255 40 17 had the same weird rollover behavior.
The 245's were on both 7.5 and 8.5. The 255 were on 8.5.
We have a few people running them locally. Consensus is they're fine, but definitely not a yok competitor for the top folksLooks like Bridgestone is bringing the RE-71RS to the U.S. Not much available yet.
I had that bucking sensation when I used to run some 245 Pirelli slick takeoffs on my MKV R32 using an 8” wheel. It’s a weird feeling but it only happened for me on one turn at Willow Springs (Big Track), never had it at any other tracks.
I always chalked it up to a rim with issue where the tire wasn’t stretched enough.
Exactly what I'm running them at for autocross too.I run mine 37f and 41r, but that’s for autox.
They won't be crying when it rains. At anything but full depth, they are terrible.I must be competing just enough, when there’s a few other competitors trying to say the V730 should be excluded from STU as they look like slicks.
