Performance rebuild on IS20
railroader
Yuma Arizona
Giant pictures!
I can't tell if its F rev or not, but it looks similar...
Sent from my SM-G935P using Tapatalk
Nice.
Sent from my XT1254 using Tapatalk
Lord_Flexington
Syracuse
15 MK7 GTI LP PP
demi9od
NC
How much and what are the specs?
x2
Looks great
x3, this is exactly what I’ve been waiting for.
Quick update:
This is now an available upgrade through GPOP Shop for the following prices:
- Full IS38 internals upgrade (compressor + exhaust) @ $695
- Partial IS38 internals upgrade (compressor side only) @ $550
This includes teardown, machining, balancing, and rebuild.
Dunno about specs, Jay didn't post yet.
jybyrd
Seattle, WA
What kind of specs are you looking for? Inducer / exducer are exact is38 spec, and the recommended efficiency range is 18-22psi at redline.
Gpop did not provide a ton of detail, as this is currently 1 of 1 without any field testing.
Ported and polished, ceramic coated, and full is38 internals ran me $915. Just the internals were $695, but I figured I would have them do it all while it was disassembled on the table.
afman916
Raleigh, NC
Do you feel the ceramic coating is necessary? I mean obviously to a degree you do, just wondering how much of a functional benefit it provides. Thanks again man, super pumped about this being an option for us now.
jybyrd
Seattle, WA
Honestly, I don't think either the p&p or coating are going to be game changers. I think they will help a bit with spool - maybe peaking 300rpm sooner between the two of those.
Oldschoolmk7
Yonder
$915 great. I assume it is balanced? Any plans to dyno or track it? Thanks
jybyrd
Seattle, WA
Yep, balance is include as part of the upgrade cost.
I'm definitely going to dyno it in a couple weeks - install is next Friday, and I want to get it dialed in with George before it hits the dyno.
Lord_Flexington
Syracuse
15 MK7 GTI LP PP
im so excited to see the results!
railroader
Yuma Arizona
Get a base before and after to see any difference
jybyrd
Seattle, WA
I have base dynos from my no-tune FBO run (220whp/275wtq), daily map (270whp/315wtq), and high boost map (285whp/315wtq). I'll run the dyno on all 3 maps so we can see the difference at varying levels of boost.
