I've been reading a lot about the headlights included in the GTI lighting package. I feel that the cut-off on mine is a little too low for the rural roads I drive at night. I understand the lights can be adjusted with an allen key. But I'm a little confused, because I hear people with lowered cars don't need to touch this screw and can use VCDS or OBD11 to auto-level the lights. Does this mean if I manually adjust the lights to a little higher, then the car will automatically set it to a lower position when I restart the car? I manually adjusted the xenons projectors on my old car and never got flashed, so I'm only looking to slightly increase the height. Also, I haven't actually found the adjustment screw. Is it easy to spot? Thanks in advance!
