Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > Member Car Journals
Old 02-28-2019, 11:39 PM   #52
CZR
CZR's Avatar
Drives: Golf 7 R
DSG, yes. Going OEM. Had APR/SSP/Dodson in mind until some people I trust told me there's no benefit and they are crap ) - was something related to the strength of the materials they use. TVS seems to be the only alternative to OEM as they use the same strength grade as stock - the other companies use hardened friction material which is bad in other ways...
Anyway, I'm not going to try any of them (at least not without strong evidence supporting them) and I don't mind changing clutches every 40-50k. If they die too soon then I may consider upgrading to DQ381 although there are mixed opinions when asking if there's any difference between DQ250 and DQ381 in terms of supported torque.
Flaps are held using special adhesive (similar to the one used to windscreens). Same adhesive was used for the roof spoiler. Probably comes off with the paint if you don't remove it using a wire
CZR is offline   Reply With Quote
Old 03-14-2019, 10:18 AM   #53
a3scott20
a3scott20's Avatar
Drives: 2018 MK75R
That MRC manifold is so SEXY! WANT ONE!!
I would just go TVS stage3 or 4 with their race clutch if torque is that high around 700NM. Mine now running their stage3 DQ381 file and it is totally transformed to another car I am enjoying every day with smarter gear shift point in D, which provided MUCH better drivability experience as the gear is always at correct position so the reaction of the car is improved a LOT.
My previous car was running DQ250 with TVS stage4 included their race clutch, to be honest it's very smooth not like others What is your torque now? I believe the stock DQ250 clutch running fine unless your 100-200KPH is 5-6s.
scott75r20's Instagram
a3scott20 is offline   Reply With Quote
Old 03-20-2019, 01:46 PM   #54
CZR
CZR's Avatar
Drives: Golf 7 R
Last pictures with winter setup! Installed the rear diffuser. Just need to adjust the silencer a little bit further down Front splitter was temporarily removed until I offer some protection to it (ceramic coating at least). It's very exposed to rock chips right there.
Didn't measure anything yet (times or power). Full service (engine/dsg/haldex) coming up these days and then I'll check where I stand.
As a daily it probably won't hit 700Nm but the full boost map (once meth is installed) will exceed 700Nm with a 6.3s~6.5s 100-200. Aiming for a 10.5 @ 402m but as I said, won't run it like that as a daily.
Glad to hear your TVS kit works good. Will take into account if needed, thanks!
Old 03-20-2019, 02:00 PM   #55
Navi
Drives: 2017 GTI SE 4DR 6SPD
looking real nice
AWE, Recaro, Forge, Unitronic, SRE, IE, 034, Bilstein, HR, Super Pro, Tyrolsport, AP Racing, Enkei, Neuspeed, Rieger, Rennline, 42DD
Instagram: https://www.instagram.com/gti_rs/?hl=en
Build thread: https://www.golfmk7.com/forums/showthread.php?t=47754
Navi is offline   Reply With Quote
Old 03-26-2019, 06:38 PM   #56
CZR
CZR's Avatar
Drives: Golf 7 R
Full service done today. Gearbox oil was in very bad shape. Glad I changed it.
Haldex and rear differential still with OEM oil. Everything else is Millers now.
Installed this big engine undertray cover, but not before I modified it to improve cooling
Also installed the SuperPro dogbone bushes
... and the Fluidampr pulley
After gearbox calibration I can certainly say it feels as smooth as a brand new stock R. Also, vibrations were reduced by the pulley (even if I added the dogbone too) and crawling in 1st or 2nd gear is as smooth as being with the engine OFF or coasting on Eco. Idle is a lot improved too.
Will go easy on her a couple of days and then I'll check how it copes with the high torque. Gear changes are ultra smooth both ways so everything ok as far as I could test on my way home.
Old 04-06-2019, 02:24 AM   #57
Navi
I think the fluidampr might be my next mod. Did you install it yourself?
Old 05-05-2019, 04:02 AM   #58
Navi
any updates?
Old 05-05-2019, 06:15 AM   #59
ATR
Drives: 2017 Golf R 6mt
Yeah, those slots are a little noisy when braking from higher speeds. Other than that, nothing negative to point out on these!
I removed the TT RS LCAs because I had rubbing issues (these are longer by about 10mm each) no matter what I tried Now I lost all that added camber and I'm looking for some adjustable camber plates suitable for DD. Any thoughts on this?
Brake deflectors were the old TT RS (8J) version. You were probably seeing current RS3 (8V) that fit on current (steel) LCAs. Those are the ones I'll get for my stock LCAs.
I believe super pro makes a different LCA for the S3 which also uses the aluminum subframe. The part number and shape of that arm is definitely different.
Funny thing about those mounts - Overall NVH is not bad but the added sounds ? That's crazy, never thought I could experience those sounds (starting engine / stopping engine / whine during acceleration).
Stopping the engine in a quiet place feels like using a stethoscope, I can actually hear everything shutting of.
I noticed the same thing with my super pro mounts. The sounds that you can hear from the gearbox and engine is pretty remarkable. Really let's the driver know what's going on under the hood
ATR is offline   Reply With Quote
Old 05-05-2019, 09:46 AM   #60
CZR
CZR's Avatar
Drives: Golf 7 R
So you notice that whine too ? It's linked to RPM but goes away if you go into neutral. Always thinking my differential or some bearings inside my gearbox are at fault. Other than that, the Fluidampr helped reduce vibrations and the difference compared to a 100% stock R are minimal.
Was busy these weeks but mods are still going strong
Some updates:
- Gearbox is 100% fine now. Going strong!
- Some early testing about current power showed a pretty good result considering I'm running a 65mm silencer (the Akrapovic) AND I'm not catless (Milltek 200cell race cat).
Considering this dyno has cooling issues, I'd say I'm pretty close to 550PS on the road. This is with 102 RON (we have this at the pump), no octane booster, no WMI, 2.2 bar.
Final map (2.4bar) will be flashed after I install the AEM kit next month.
Some Dragy runs showed me 10.87s @ 402m considering my 60ft is awful compared to last year's stage 2 setup (when I was running 1.63@60ft). Tested at 5C ambient temp - full weight, etc.
Engine bay cleaned and close to final configuration.
Car weighs 1560kg (damn sunroof again!). Would probably need to shave off some kg if I want to try break some impressive times.
Old 05-05-2019, 03:29 PM   #61
Thumbs up
Great numbers.
ED Moose E50 ECU tune / ED DSG Stage 2 tune / Tomioka IHX475 Turbo / IE IC / MAP cat+res DP / Autotech HPFP / PR 450 LPFP / Uni TIP / EQT TMD and Pipes / NT-05s on Asstins / Full Stealth Mode
Old 05-06-2019, 12:47 AM   #62
Navi
I would recommend the super pro lower control arms if you want a little additional camber and caster
Old 05-06-2019, 01:14 AM   #63
CZR
CZR's Avatar
Drives: Golf 7 R
I'm not 100% sure those are the same length as stock. Was thinking to try the new SuperPro camber mounts instead
Old 05-17-2019, 10:46 AM   #64
CZR
CZR's Avatar
Drives: Golf 7 R
Grabbed a new set of TT RS calipers, powder coated them, added RacingBrake pistons and seals, titanium bleeders and StopTech PosiQuiet pads. Will get these mounted once I figure out the rear setup.
Old 05-17-2019, 12:57 PM   #65
Navi
wow those look nice
Old 06-14-2019, 01:13 AM   #66
CZR
CZR's Avatar
Drives: Golf 7 R
No, I did not stop. Can't do that...
Got a rear set too hehe. Waiting for new pads and some other stuff so I can do them all at once.
SuperPro top camber mounts came in. Can't wait to try them, hopefully there won't be much NVH.
And already started gathering/preparing the needed parts for WMI.
Grabbed a new set of charge pipes and modified them with additional WMI bungs
Current times before WMI with 100 RON fuel and street tires (and not on prep. surface)
Old 06-14-2019, 01:20 AM   #67
Navi
what coilovers are you on again? I know you posted the before but I forgot. Was ohlins? Let me know how the superpro camber mounts are. I'm thinking of switching to them but curious about NVH...
Old 06-14-2019, 01:42 AM   #68
Nice.
