tonipepperoni77
- Mass
Was wondering for those running 17s for winter wheels what PSI are you running.
Sent from my iPad using Tapatalk
Around 35psi IIRC. There's a chart floating around the forums somewhere which tells you how to determine the correct pressure.
Edit: here you go:
http://static1.1.sqspcdn.com/static/f/589830/23447320/1378330097907/Discount+Tire+inflation.pdf
What does your manual tell you?u
Aren't the OE tire pressures calculated for a full load of 5 people weighing x-number of pounds and luggage (the gross vehicle weight on the door jamb sticker)? I run 35-36 PSI instead of 39 PSI since I normally only carry about 300 pounds or so over the curb weight.
The chart linked above is for cross referencing a given tire at a given pressure to another tire size and the corresponding pressure.
Same as with summers.Was wondering for those running 17s for winter wheels what PSI are you running.
Provided load rating is about the same (90 - 92), which is commonly the case.
Adjust to taste, higher psi will ride rougher, but in actual snow will perform better and give better milage, but on the road will wear out the center faster than the sides.
