Wheels and Tyres Question
Tamer
UAE
Hello Guys, just bought my GTI Clubsport, it came with 18" wheels, VW doesn't recommend 19" as it may cause cracking of the panoramic roof!
Any one has experience to share on this topic? i ordered OZ 19" anyway :):):) just need to hear the counter arguments if any.
One more question, what is the widest tyre i can go for without causing friction with fenders? stock is 225, i will go for 235, wondering if i can go to 245??? any idea please?
Thanks
HOT H2O
Canada
Thanks
Weird, as many Pano roof Golfs including the Clubsport can be had with 19" wheels?
235/35/19 is the factory recommended tire size for 19" wheels
Axles of Evil
Louisiana USA
Not yet
Thanks
Running 19's and.....well, no cracks as far as I can see. :rolleyes:
Axles of Evil
Louisiana USA
Can I go for 245? Would it rub?
Sent from my SM-G935F using Tapatalk
Would not recommend that without checking the wheel offset. If you are around 43-46 ET, it will be OK
I found this thread VERY helpful, which is what I used when I did the leap to 19's. I included my GTI in the thread at the time. I am running ABT 19's and the handling difference is night and day.
http://www.golfmk7.com/forums/showthread.php?t=18334
BTW, I think somebody is pulling your leg on the crack sunroof thing. There is no physical difference in the standard whees to 19's as they are approximately the same overall dimension, the only thing I can think of is slightly....I mean slightly more radial inertia...but then again I would not expect any major operational dynamics from the two. The wider tyre increases the handling portion.
Tamer
UAE
Thanks a lot; and thanks for the thread I found it useful too; u think that 245 would really not rub against fenders??? If I buy them and they do then it is money down the drain ???
Tamer
UAE
just checked, my ordered wheels are et48, so i guess that rules out 245 as this is already 3mm more offset than the et46!
Geomets
South-Eastern Europe
Golf mk7 GTI
With ET48 the tyre will be 2mm outwards compared to stock + half the wheel width difference . With ET46 the tyre will be 4mm outward + etc...
