Update:
Now that my bent track wheel is straightened and it doesn't sound like I'm driving on lumpy logs, I was able to determine more clearly if there's any hum on my track set.
There isn't! I drove this morning with cold roads and cold tires, autocrossed, and drove home on hot roads and hot tires. Wide variety of road textures and speeds. Very little, if any hum. So now the task is to determine what difference(s) are the cause.
- Is it the tires?
- If so, is it:
- The tread pattern? Both my Conti ECS and Falken FK510 hummed and their tread patterns are quite different. The Contis didn't get humming really bad until about 5k in. The Falkens hummed brand new. The Kumho V730 track tires have very little tread pattern at all.
- The tire size? I'm running 235/40r18 on 18x7.5 stock wheels (hum). My track set are 255/40r17 on Neuspeed 17x8.5 wheels (no hum).
- The tire construction? The track tires are certainly built differently. Thicker sidewalls, softer compound.
- The tire pressure? The larger size on my track set calls for lower pressure (30-31 psi)
- Is it the wheels?
- If so, is it:
- The wheel construction or design? 5-spoke Austins vs. whatever the Neuspeeds are.
- The wheel size? 18x7.5 vs. 17x8.5
- Is it the wheel-tire combo?
- If so,
- Could an 18x8 wheel solve it?
- Could a 225/40r18 tire solve it?
It's hard to know where to go from here. I'm not in the camp of believing it's the specific tires I run today (the FK510s) because the Contis before them were humming too, and both tires are repeatedly tested and reviewed to be very quiet. My gut is leaning towards the wheel-tire combo and that I should try a different size combo. I dunno.
Another big difference is both the Contis and these Falkens I can tap/slap the tires and hear them ring at pretty much the seem frequency of the hum I hear. The track tires barely have any sort of ring at all.
