No, but i've used gyeon mohs, cquartz uk 3.0 and optimum gloss coat.Do you have any personal experience with Avalon King? I've seen it in person and spoken to others who have used it with great results.
RS3 brake deflectors came in. Pic is next to my $8 modified GT3 ducts. I'm going to test to see which cools better. If the GT3 deflectors work better, I'll have to figure out a better way to secure them. Maybe I'll bolt them to the RS3 deflectors?
I just got this too! I have a 2019 R and the RS3 ducts required no trimming and fits without hitting the PP Brakes or drive shafts
As others have said, the Golf/GSW is 50mm and the Alltrack/GTI/R are 55mm. Just gives you some more options suspension wise. I plan on using the stock Alltrack rear shocks and springs, so just need to figure out the front struts.Why would you be switching to Alltrack knuckles?
Cargo box looks perfect.After waiting for what felt like decades, my cargo box finally arrived! (Thule Vector M)
I think the "others" you mentioned are me, haha. I suppose there are more options in 55mm if you're looking at some of the more niche/expensive/advanced coilover kits available. But then I wouldn't expect that you would also be installing the BES kit and using stock Alltrack rear shocks/springs. Off the top of my head Bilstein, Koni, KW, and Solowerks offer most of their respective lines in 50 and 55mm form.As others have said, the Golf/GSW is 50mm and the Alltrack/GTI/R are 55mm. Just gives you some more options suspension wise. I plan on using the stock Alltrack rear shocks and springs, so just need to figure out the front.
True, though the BES kit limits what you can use as far as coilovers. The rear adjustable perch can't mount on top of the spring, so Bilstein is out. The Lift ring sits on top of the rear spring for the BES kit, so I'd need to find one that mounts the adjustable perch to the control arm. For now I figure I'd see what the lift is like. If not, i'll more than likely attempt to do coilovers or lowering springs and aftermarket shocks to retain the stock ride height at the minimum and see if I can tune it to where I like it.I think the "others" you mentioned are me, haha. I suppose there are more options in 55mm if you're looking at some of the more niche/expensive/advanced coilover kits available. But then I wouldn't expect that you would also be installing the BES kit and using stock Alltrack rear shocks/springs. Off the top of my head Bilstein, Koni, KW, and Solowerks offer most of their respective lines in 50 and 55mm form.
its gonna be majestic. brakes cold as ice, but hopefully won't slow you down too much?Yeah, I bought the RS3's because the GT3's are hard to get to stay put. But after seeing how small they are, it makes me think I could bolt or expoxy them together to make a kicks asx duct.
Where would you wear it then? (sick lid BTW)Got this as a xmas gift from my girl, just arrived from FedEx. I am a little hesitant to wear it to the race track if you know what I mean...
stiggyGot this as a xmas gift from my girl, just arrived from FedEx. I am a little hesitant to wear it to the race track if you know what I mean...
