onestockgtigt
- Guatemala
- GTI MK7
Hey guys,
So I noticed the water temp in my car is a little bit above the normal temperature. VCDS got me the following codes:
23651 - Heater Support Pump
P16C6 00 [032] - Running Dry
Intermittent - Not Confirmed - Tested Since Memory Clear
23652 - Heater support pump
P16C7 00 [040] - locked
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 9
Date: 2000.15.00
Time: 31:63:63
Here is also a pic of the temperature gauge.
Should I worry or change the heater support pump ASAP?
Can this cause or be able to cause any other problems with the car?
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Date: 2000.15.00
Time: 31:63:63
