vortex/ mpi / rs3 brushless install gremlins/problem solving
Lurchalicious
NKY
Sorted the leak. Onto the LPFP.
Lurchalicious
NKY
using the apr pressure tester i found all my leaks!
problem still with the lpfp, duty cycle is very high for the low amount of pressure being made. logs make it look like a retstriciton.
could stock lines really cause that amount of restriction? check valve? Im being told that i should have about 4x the pressure at the duty cycle the pump is at.
i removed the pump, found crud and dirt in the basket and sock; cleaned it out and ensured the ground was cleaned and connected. still no change it seems
next hypothesis is the fuel controller got hurt when the original fuse blew (10 amp) because the shop didnt swap it. should have done it myself but whatever, here we are.
i have a new controller and pump on the way from audi. can/has anyone been able to diagnose a bad control unit that still operates?
Rare Ara S3
Michigan
2017 Audi S3, GTI
That APR leak tester is a great tool.
how much was a new black controller ? I’m still running the silver one.
Lurchalicious
NKY
Found some boost leaks and fixed them. Obtained a new pump and controller
We are running stock fuel lines from the pump forward. There is a 5/16" T fitting that feeds the european OEM MPI rail (plastic one).
This is with just a new pump controller on the pump I originally installed
https://datazap.me/u/lurchalicious/log-1650904661?log=2&data=8-14-29-31
https://datazap.me/u/lurchalicious/log-1650904661?log=1&data=8-14-29-31
https://datazap.me/u/lurchalicious/log-1650904661?log=0&data=8-14-29-31
This is with a brand new pump and controller
https://datazap.me/u/lurchalicious/log-1650910641?log=0&data=14-29-31
https://datazap.me/u/lurchalicious/log-1650910641?log=1&data=14-29-31
https://datazap.me/u/lurchalicious/log-1650910641?log=2&data=14-29-31
At this point I'm not sure where the issue is. I'm running a brand new pump and controller. Perhaps the physical install of the T fitting? The OEM Euro Rail needs to be drilled out? The check valve on the quick disconnect in the engine bay?
Michael gti07
South of Cleveland, North Coast of Ohio
Rabbit Cornflowerblu
Weak possibility the plastic T needs the ends deburred, i.e. chamfered, to lower turbulence when flowing from different parts.
? drop the check valve to see what happens?
? no extreme curves or loops ?
scrllock
MI
You should get one, the silver one definitely has problems running an RS3 pump.
I'm confused. Your pressure and duty cycle % look fine. You're not even cracking 70% and you're holding over 90psi. What's the problem?
Lurchalicious
NKY
According to the tuner, it should be at a lower duty cycle running that psi. I have the same question but apparently it's looking like a large restriction.
scrllock
MI
Only obvious answer is that he's used to aftermarket MPI rails. The OE euro one would be a slight restriction. But the log doesn't look terrible to me
Lurchalicious
NKY
using an aluminum earl's tee fitting, will have to check the oem rail opening for burrs etc
Talked to A2B today and they gave some good insight - thank you A2B! check valve is going to be removed this week once parts arrive.
also apparently I'm back to having a boost leak, 80% WG cycle is too high for 25 psi on a vortex XL. :(
Rare Ara S3
Michigan
2017 Audi S3, GTI
But I wonder what the failure rate really is. We read about it via a small portion of vehicles made up of enthusiasts. And of that group how many of them cram the thing under the rear seat cushion? Good way to overheat something. Nevermind the ones that are overdriven.
just a thought. Mine is in the factory location basically. On top of the tank.
scrllock
MI
eh, as far as the rs3 pump goes, I'd just feel better running the OEM controller designed for that OEM pump. odds are it's a combo of heat, tuners hiding fuel pump DTCs that go unaddressed, and pulling a bit more current out of the silver controller than it's designed for in OE use.
Lurchalicious
NKY
Changed out the line from the hard pipe in the engine bay to the HPFP with Earl's EFI line rated for 255 PSI. Moved the fuel Tee.
https://datazap.me/u/lurchalicious/log-1651264766?log=0&data=8-14
https://datazap.me/u/lurchalicious/log-1651264766?log=1&data=8-14
https://datazap.me/u/lurchalicious/log-1651264766?log=2&data=8-14
Tightened up some spots I believe the boost leaks may have occurred at, put some more lip on the pipe with a bead roller.
I'm not really sure what else I can do to satisfy the issues now.
Here are some pictures of the fuel line setup.
I am changing out the fuel pressure sensor to the same one APR uses - "bosch 0261230414", the one i have on is "bosch 0261230415".
